KS7 Final render not looking like real time render?
Started by WPBAlx, August 06, 2017, 09:37:42 PM
WPBAlx
The final renders are not looking like the renders i'm working on in KS7.? Any ideas why this is happening? KS6 still installed and not having any issues. Any ideas??
I guess sending this to support@luxion.com would help that they can look into your settings.
Do you run with max samples mode or advance render settings?
Do you tried to import the geometry into a fresh new KeyShot 7 scene and apply the materials instead of loading a KS6 scene? (does this effect still appears?)
Hope that helps to find the solution.
cheers
What image format did you render to?
Can you share the scene? Indeed, support@luxion.com will be able to sort this out.
WPBAlx
