1 Hour
1 Day
1 Week
1 Month
Forever
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Help
Search
Login
Register
KeyShot Forum
Technical discussions
Extending KeyShot
Network Rendering
How to use all of the cores on the network
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How to use all of the cores on the network (Read 8511 times)
mykalh86
Newbie
Total likes: 0
on:
August 11, 2017, 07:03:12 am »
So we have Keyshot 7 and Keyshot Network Render Queue with 32 cores. How can we enable all of these cores on the network? We are currently using only 12 out of the 32.
Logged
Guest
Re: How to use all of the cores on the network
Reply #1 on:
August 11, 2017, 07:04:40 am »
Install Network Rendering on the machines on the network that you would like to use, and then run the configurator to use them as workers.
Logged
mykalh86
Newbie
Total likes: 0
Reply #2 on:
August 11, 2017, 07:35:46 am »
We have the Network Monitor and have our main server as the "Master" it shows that there are 8 cores and 4 are allowed on it.
Logged
Hero Member
Total likes: 135
Reply #3 on:
August 11, 2017, 08:56:24 am »
Same happened here when the IT guy was changing the number of cores in the VM, he went from 6-8 but NW never recognized them until I re-ran the configurator and changed the number of allowed cores.
Logged
MrTomB
Newbie
Total likes: 0
Reply #4 on:
August 17, 2017, 03:16:27 am »
at the moment we have to run the configurator to change the number of available cores, we cannot do it in the monitor
Also, to the OP have you set up each workstation etc as a worker?
Logged
Hero Member
Total likes: 135
Reply #5 on:
August 17, 2017, 07:12:40 am »
Yes you have to re-run the configurator on each slave machine and change the number of cores allowed. Can't do it through the monitor, even on the slave. That would be nice
Logged
MrTomB
Newbie
Total likes: 0
Reply #6 on:
August 17, 2017, 07:32:33 am »
The manual shows that you can do it through the monitor and the options and buttons are there but nothing happens
Logged
Hero Member
Total likes: 135
Reply #7 on:
August 17, 2017, 11:01:13 am »
Try it by re-running the configurator and see if it changes. that might be grounds for a bug report if it works.
Logged
mykalh86
Newbie
Total likes: 0
Reply #8 on:
August 24, 2017, 09:32:06 am »
So it all came down to the PC that we have on our server. It has 8 cores but IT only allocated 4 to us to use with Keyshot Network Render.
Logged
Hero Member
Total likes: 135
Reply #9 on:
August 25, 2017, 06:26:09 am »
Is it being run as a virtual machine? That's where I had a little trouble, since I know virtually (
) nothing about virtual machines, I didn't know that the number of cores could be manipulated.
Logged
Print
Pages: [
1
Go Up
« previous
next »
KeyShot Forum
Extending KeyShot
Network Rendering
