Awsedr
Started by awsedr9, August 30, 2017, 01:30:05 AM
Contour render problem!! When rendering a contour, they will be created ,,hair,, (faults)
0 (0%)
hair
3 (100%)
problem
0 (0%)
Total Members Voted: 3
awsedr9
Hi, please,,
In real time render in Keyshot is all OK
But When rendering object a contour, they will be created ,,hair,, (faults).
Esben Oxholm
Hi awsedr9.
You should be able to avoid this bug by rendering using the 'max samples' rendering mode.
Best,
As Esben said, Maximum Samples or Time will not have this issue.
If you would still like to use Advanced Control, then increasing Anti Aliasing will help to get rid of these artifacts. You can try a value of 8.
