wallpaper
Started by rfollett, August 31, 2017, 12:04:34 PM
rfollett
still trying to master interior lighting....
rfollett
another...
Esben Oxholm
Hi there,
What is your main light source? It looks a bit flat.
Having a room like that, I would suspect the light to be coming through one or more windows, and thus create some shadows.
rfollett
#3
Hi Esben.
scene just lit from HDR..
http://prntscr.com/gfoz6j
Esben Oxholm
Ah, okay.
I would probably try and close the room and have the lights come trough a bunch of window openings.
Maybe using just the HDRI and/or adding in area light planes at the windows.
I'm not too experienced with interior shots, so take the advice with a grain of salt :)
Esben Oxholm
Could you perhaps share the scene?
Would love to give it a try.
rfollett
already attached as ksp file in my post.. thank you Esben
rfollett
think original might be broken so here is another!
jet1990
as Esben said its looking a little flat. The first thing that jumps out at me is the flatness of the wooden floors. (it sort of looks as though its a vinyl applied to the floor and not actually physical wooden slats) i would create a bump map for this to add that level of realism. Also try out different HDRIs as some are really good for the interior scenes.
rfollett
when should I use Global illumination setting in the lighting panel?
jet1990
i would use it whenever i am building an interior scene.
rfollett
here is another render..
jet1990
i had a very quick play with it. I noticed straight away that it wasn't an enclosed room. Whenever recreating real world scene - i would close the walls off and have a light coming through the windows. I also placed a sphere in there to illuminate the scene a little better. the materials need changing (bump height etc) but i think it gives a more natural look to it.
rfollett
rfollett
#14
now with closed walls and 3 light sources
