Author Topic: Admin rights needed to start NW Monitor 7.0.456  (Read 5947 times)
Offline Nemo
« on: September 06, 2017, 03:29:52 am »
We use NR in a ActiveDirectory environment. Users do not have admin rights.
I set up NR logged in as Admin. Everything works well.
A regular user cannot open the Monitor. When he/she clicks the icon, nothing happens.
We made a temporarily workaround with this cmd file:
Code: [Select]
c:\
cd "C:\Program Files\KeyShot7 Network Rendering"
runas /savecred /user:DOMAIN\AdminUser "C:\Program Files\KeyShot7 Network Rendering\bin\keyshot_network_monitor.exe"
However, at the first time a user uses this cmd file, I still need to enter my admin credentials.
Currently this works (aside from the need to copy the cmd to every PC and putting in my password a dozen of times). Also, I do not see this as the most elegant solution from a security point of view. Can you please update (and test) NR so it works flawless in a corporate-environment? I hope you develope 'Keyshot Network Rendering' with Active Directory in mind ... ?!
« Last Edit: September 06, 2017, 03:57:56 am by mkiesel »
  • Guest
Re: Admin rights needed to start NW Monitor 7.0.456
« Reply #1 on: September 06, 2017, 11:45:03 am »
Fixed in the next update.
Offline Nemo
« Reply #2 on: September 06, 2017, 12:04:29 pm »
Great, thank you!
Can you already estimate - will you release it soon / this year / next year / ... ?
Just curious if I can wait rolling out my current work-around ...
  • Guest
« Reply #3 on: September 06, 2017, 01:24:52 pm »
You can contact [email protected] right now and get the latest build. It is closed to the final build - would be great to have you confirm that it is working for you.
Offline Nemo
« Reply #4 on: September 07, 2017, 10:09:58 am »
Thanks.
First impression: version 7.0.457 works flawless without Admin-rights.
