Cutaways and filled section / Boolean system
Started by Arian Shamil, September 12, 2017, 01:40:48 PM
Arian Shamil
There is any plan to implement a cutaway function?
Cutaways completed of filled section....
Thanks in advance
Arian
Arian Shamil
So, I up this.........need "Boolean cut" to do some animation with KS
Arian Shamil
Up to this function...it would be really nice to have this too....
(always for mechanical animation, without using external software)
CoalHedgehog
Seems to be one of the most requested things in the Wish List section.
+1 from me.  :)
KeyShot
We do have a way of doing it in KeyShot 7.2, but it needs to be extended to add interface boundaries to be truly useful, so we are continuing to work on it. It will happen :-)
Arian Shamil
Yess!!! :)
Can't wait to use it :)
And if it can be animated too.......it would be awesome :)
Vini.longo
Quote from: KeyShot on January 03, 2018, 05:08:46 PM
Can you explain me how?
By the way +1 on that request.
Thanks in advance!
Serge Ortmann
Guten Morgen  :)
do you mean something like this?
I created it in KeyShot with the Materialgraph and number fade animation.
KeyShot
The cutaway in v7 is not easily available. In v7 is implemented in several different forms both as a geometric operation and a material operations.
We decided to wait until v8 with cutaways to make sure we had a technique that would support all the features (caps, exclude objects etc.) as well as work with the configurator. It has been implemented now, and we are testing it internally. It will be in v8.
Serge Ortmann
Quote from: KeyShot on May 03, 2018, 10:54:36 PM
Glad to hear that, as many people already said here, it is a game changing possibility!
I found a quite simple solution, which can be optained in a few minutes.
Here's the download link to a cutaway animation. You can see the properties inside the Material graph of the big box, to maybe understand, how things work out.
https://files.fm/u/xc8kmg3w
