Rotation anomaly ?
Started by zooropa, September 14, 2017, 09:45:20 AM
zooropa
I am trying to rotate a cylinder. Why the translation values move too ? I am just using the rotating handle.
This is not allowing me to rotate my model precisely. Each time I try to rotate it the model rotates off axis.
I think a KeyShot scene, or at least a screenshot, are needed to troubleshoot this issue. A bit more context would be helpful.
As for rotating with the Move Tool in general...
The Move Tool centers on the bounding box of the selected geometry, not the origin/pivot. If the center and origin aren't coincident, than the translation values will update as you rotate with the Move Tool.
zooropa
#2
Thanks DriesV. Is there any problem to correct that from rhino ?
You can check the problem with this sample scene.
Regards
Edit: I made a new cilinder in rhino...when I rotate in KS ..the translation parameters also change (???)
