Changing an Image's Dimensions
Started by MisterNeil, May 12, 2011, 06:57:38 AM
MisterNeil
In Keyshot's Options palette is there a way to change the dimensions so that the width and the height are the same? My client is asking that I create a turntable rendering so that the width and height are both 550 pixels per inch. Can this be done in Keyshot? If so, how?
For now, my work around is to import the 100 frame rendered files into Photoshop and later crop the width to 550 pixels per inch. Any suggestions on how to do this in Keyshot 2, version 2.2.52 Intel Mac, is appreciated. Thanks!
Neil
Go to Options, Realtime, uncheck lock aspect ratio, then set your height and width, then check lock aspect ratio. Done!
