Author Topic: zbrush to keyshot  (Read 5890 times)
Offline corny
zbrush to keyshot
« on: September 20, 2017, 07:53:14 am »
I have sent my subtools to Keyshot for texturing and rendering. When I update a mesh in zBrush, and hit BPR to send it back to Keyshot, all of my carefully constructed materials get replaced with the zBrush red clay, and all my Keyshot materials get wiped out! What am I doing wrong? And how can i update the model if i make changes on zbrush??
Please help!
Offline Josh3D
Re: zbrush to keyshot
« Reply #1 on: September 20, 2017, 08:45:40 am »
Can you tell us what version of KeyShot and ZBrush you are using?
Offline corny
« Reply #2 on: September 21, 2017, 01:34:42 am »
I using zbrush 4R8 P2 and keyshot 7.1. thank
  • Guest
« Reply #3 on: September 21, 2017, 09:41:51 am »
Please contact Pixologic for this. Their team developed the Bridge and intimately familiar with the workflow.
Offline corny
« Reply #4 on: September 23, 2017, 01:42:50 am »
Thank.. i had email to pixologic about the matter.  anyone can help here?
try the step below.. not sure is kepshot problem or zbrush problem.
1. create any model in zbrush and paint in.
2. send to keyshot and make some label.
3. save and close zbrush. (MUST CLOSE THE ZBRUSH)
4. REOPEN the zbrush and open the same model which just now create.
5. send the model to keyshot.
6. all the label done in keyshot is gone.
hope you understand what i mean. thank you
pls help
« Last Edit: September 23, 2017, 01:47:07 am by corny »
Online DriesV
  • Administrator
  • Total likes: 62
« Reply #5 on: September 23, 2017, 02:16:30 am »
KeyShot relies on the original material name from the modeling application for dealing with materials on model updates.
Unfortunately, Zbrush seems to generate those material names randomly across different Zbrush sessions. So when you send the model to KeyShot after having restarted Zbrush, KeyShot receives a different material ID (even though it is the same model) and assumes (correctly in our Live Linking workflow) that it is a newly assigned material. KeyShot then discards any existing material and Label setups.
I think this is an issue for Pixologic to resolve.
Our integrations with other modeling tools don't have this issue with random material IDs.
Offline corny
« Reply #6 on: September 25, 2017, 08:43:18 am »
Thank you so much
Offline Metin Seven
  • Jr. Member
  • Total likes: 2
  • metinseven.nl — visuals, illustrations, 3D design
    • Portfolio
« Reply #7 on: October 05, 2017, 12:09:36 am »
Thanks for your reply, Dries. I was wondering if there's a workaround regarding this issue. At the moment I save each material I've assigned to the scene in Keyshot, then when I update the scene I manually reapply the materials to each part. But it's a hassle, and I hope this will be fixed soon.
  • Guest
« Reply #8 on: October 05, 2017, 05:21:24 pm »
Please contact Pixologic for this. They are the developer of the Bridge to KeyShot.
Offline e1two
« Reply #9 on: October 20, 2017, 08:04:08 am »
If you change the default zbridge setting to "group according to material"
zbrush will no longer assign a material id at random but respect the
internal id's according to the list in your material browser panel.  Of course
this will change from setup to setup but if you change your work as a
zpr file it should always work (in theory)
Not 100% sure, but so far this method works, even if you close zbrush
and keyshot and load everything back up from scratch.
« Last Edit: October 24, 2017, 08:53:05 am by e1two »
