Radio Button missing on Keyshot 7.1?
Started by rod, September 20, 2017, 01:00:46 PM
rod
When I already have geometry in a scene in Keyshot 6.3 and I hit the Import Icon at bottom of screen I get the following options:
1. Add to Scene
2. New Geometry
3. Update Geometry
Keyshot 7.1 leaves off # 2. Option. I have to go to the Menu "File/New to wipe out old geometry before I can import new geometry. The issue is that I now have to start over and recreate elements in the environment whereas in Keyshot 6 I could just import the new file into the existing environment setup.
Could we not have the button back?
Thanks, Rod
We removed this option to protect those that accidentally delete existing geometry. You can always select "add to scene", and then delete the old model.
Or you can save a new startup scene under preferences > general. This way KeyShot will always open with this new startup scene which contains all your settings.
