rendering . paused then unresponsive interface
Started by bill chalmers, October 26, 2017, 03:03:41 AM
bill chalmers
when i hit render -  'Paused' immediately appears on the screen along with log window  with lists of errors red and yellow . the render control panel is greyed out and although the cursor can be moved about the screen the all the  buttons are responsive . I have to shut the programme down by pulling the plug on PC. Ive tried this several times with same result . I am new to Keyshot . PC using windows 7 . Any suggestions ? please
can you hit clear or dismiss the error dialog box? I know when i have that happen I have to get rid of the error box first.
Here some other things to try before pulling the plug-
1) CTRL-ALT-DELETE to get to the windows task manager, and force quit the application
2) Right click on the icon in the dock and chose to close window, that should bring up the close program  window and you can quit it from there.
that's all I have, I'm by default a mac guy, so my knowledge of this stuff for windows is a little limited.
Let us know what happens.
I can't read the error message, but I think this is an issue that first occurred with KeyShot 7 running on Win7. This has now been fixed. Please make sure to update to KeyShot 7.1.51.
bill chalmers
- all the options for closing are unresponsive . I can still open other windows for other application's etc but anything related to Keyshot  remain unresponsive . thanks for your reply
bill chalmers
@ thomasteger  - heres the message from log window
KeyShot 7.0.438 Log File - Fri Oct 27 10:25:46 2017
OS: Windows 7 64 bit
(09:22:43) Failed to load 3d connexion dll
(09:22:45) Xml file does not exist: "C:/Users/bchalmers/AppData/Local/Luxion/KeyShot 7/startup/offline/welcome.xml"
(10:08:55) QWindowsWindow::setGeometry: Unable to set geometry 22x41+640+280 on QWidgetWindow/'KAccordionWidgetWindow'. Resulting geometry:  116x41+640+280 (frame: 8, 30, 8, 8, custom margin: 0, 0, 0, 0, minimum size: 22x41, maximum size: 16777215x16777215).
(10:11:44) Saved render to C:/Users/Public/Documents/KeyShot 7/Renderings/green jug.15.png
(10:17:25) QWindowsWindow::setGeometry: Unable to set geometry 101x26+640+507 on QWidgetWindow/'BorderButtonWindow'. Resulting geometry:  116x26+640+507 (frame: 8, 30, 8, 8, custom margin: 0, 0, 0, 0, minimum size: 0x26, maximum size: 16777215x26).
(10:19:13) Parameter "color" not found on "lux_leather_tex"
(10:20:14) Invalid edge types 3 and 0
(10:22:19) QWindowsWindow::setGeometry: Unable to set geometry 101x26+640+507 on QWidgetWindow/'BorderButtonWindow'. Resulting geometry:  116x26+640+507 (frame: 8, 30, 8, 8, custom margin: 0, 0, 0, 0, minimum size: 0x26, maximum size: 16777215x26).
(10:24:53) Access violation (address 000007FEEA15642A)
(10:24:53) Fatal error in luxrender.so (000007FEEA150000,1413120) at 000007FEEA15642A
(10:24:53) Critical error rendering image
(10:24:53) Access violation (address 000007FEEA7B1D73)
(10:24:53) Fatal error in luximagesmp.so (000007FEEA7B0000,118784) at 000007FEEA7B1D73
(10:24:53) Internal error. Please report to bugs@luxion.com
(10:25:00) Access violation (address 000007FEEA15642A)
(10:25:00) Fatal error in luxrender.so (000007FEEA150000,1413120) at 000007FEEA15642A
(10:25:00) Critical error rendering image
(10:25:00) Access violation (address 000007FEEA7B1D73)
(10:25:00) Fatal error in luximagesmp.so (000007FEEA7B0000,118784) at 000007FEEA7B1D73
(10:25:00) Internal error. Please report to bugs@luxion.com
Yes - as suspected. Thanks for sharing. Please upgrade to 7.1.51. Everything will run smoothly then.
bill chalmers
@thomasteger
  just to check  - is this the same -  KeyShot 7.1.51 Network Rendering.
This is network rendering. You need the update installer for KeyShot. If you are connected to the internet, you can "check for updates" from within KeyShot under the Help menu. That will give you the download prompt for KeyShot 7.1.51. Or download from our website.
