WACOM PEN
Started by BienAvous, October 26, 2017, 05:36:49 AM
BienAvous
Hi everybody,
I'm Vincent and it's my first post on this forum.
The pen was modeled with Rhinoceros and rendering with Keyshot.
Magnus Skogsfjord
#1
That's a superclean looking nicely lit first post! Loving the mood you've made here, as well as the subtle bump/roughness (or maybe just low sampled?) texture.
Only knitpicking would be those annoying banding issues in the gradient. If you've done these in photoshop, you can usually remove these by making gradients in 16 bit mode. To remove them, I've had some success by adding just enough noise to remove the banding, then reblurring it using gaussian blur (in 16bit mode).
NM-92
I've found another method that reduces banding directly inside of KS. I just put a plane behind with a solid color with a gradient texture. I make the background gradient there so it renders with the model. I've used that on my Plastic Inhaler model with pretty solid results. It's worth the try.
Josh3D
Welcome! Love the clean look of these too.
Nice suggestion Nico!
BienAvous
Thanks you Guy's!
@Magnus Skogsfjord : For the texture it's a subtle bump/roughness combined with a low sampled. ;)
I used photoshop for the gradient post prod.  Thanks for your inputs!
@NM-92 : Thanks for your suggestion! I think I try this in my futur rendering.
Very clean images indeed.
A round of high fives to the poster and all people providing valuable feedback here.
