Keyshot Low CPU Usage
Started by HamedHem, October 28, 2017, 05:32:45 AM
HamedHem
Hi Guys ,
I have a serious problem with thinkbox deadline keyshot submitter script .
Here I have attached deadline render script for key shot but I have a problem with this , when running script from keyshot console the CPU usage keeps around 14 % but when render the scene directly from keyshot CPU works properly 100 %.
CPU Model : Dual Xeon 2699v4 ( I have tested the script on i7 5820 K and again the same problem 70 % max CPU usage )
Notice that  this happens file to file , for some of the files works fine but some other not , ( let me know if you need a file to check this ) .
Really need your help to fix the issue ASAP .
Thanks in advance ,
Regards.
