Weld Seam creation
Started by JasonM1972, November 06, 2017, 02:23:11 PM
JasonM1972
Quote from: MWo on November 07, 2017, 10:54:08 PM
Hello Jason.
Here we go. I took some minutes. All details can be found in the attached package.
Thank Will for the inspiration to the right direction. And I also thanks Esben (even if I didn't checked your file).
I changed the color a bit just to give more control. And I used my favorite environment.
Thanks very much for this, its really appreciated (Thanks to Will and Espen also) and I wish I could buy you a beer.
Now, I'm currently looking at your settings and applying them to my version, I need to understand how you can get there and I cant. will keep you all posted
Kind Regards
Jason
Hello Jason
I think it would be helpful if you look into the scale (X, Y direction) from the cylindrical mapping. As Esben mentioned this needs to be fit to the geometry. If I'm right it was about 0.001 in X and 1 in Y. The values can be different if you activate the DPI option with a value of 72 (what is defined in the texture file)
I like your idea of the beer. It would be a very interesting session with Will (located in the US), Esben (located in Denmark) and you and me (from Hamburg / Germany) - but this will not happen too soon?!
Maybe you'll post your final solution.
Kind Regards
Esben Oxholm
Quote from: JasonM1972 on November 08, 2017, 04:48:34 AM
Quote from: MWo on November 09, 2017, 10:35:05 AM
No problem. I can be in Hamburg on a four hour notice. Just let me know when you put the beers in the fridge ;)
Quote from: Esben Oxholm on November 09, 2017, 11:07:30 AM
I wanna see this happen 8)
