issue with transparency
Started by Arian Shamil, November 20, 2017, 05:50:30 AM
Arian Shamil
Hi to all
I'm having big trouble rendering frames of a transaprency material with some light reflection on it....
On the Keyshot viewport I've one result....clear and correct.....but if i open my frames in photoshop or AE the light goes wrong...the reflection is not strong as in the keyshot viewport....
i can reach a good results only if i export on tiff32 bit but the frames are huge.....there is a chance to obtain a good results with png too?
Esben Oxholm
I experience the same thing.
I've been able to solve it in my projects by isolating the reflecting parts using the clown pass and duplicate it as a separate layer a couple of times until I had the amount of reflections that I needed.
Maybe the relfection pass now available in KeyShot 7 would be a great help?
Arian Shamil
Hi Esben, thanks for the reply ;)
I've resolved rendering a Tiff instead a png.....but now I'm ecountering some other weird problem....
When i do my composition in after effect....If i swtich to 32bit, i can see the light showed properly......and this in AECS5......if i do it in AECC.....it doesn't work XO........It is really a pain :(
