stain in my model render
Started by ramizramo, November 21, 2017, 05:24:26 AM
How can I solve it
jewellery render stian in my ring render
1 (100%)
stain problem in my render
0 (0%)
Total Members Voted: 1
ramizramo
Hi, I am living a problem in my render and could not understand the reason. Also I added the photo.
If you have any idea how can I solve it, I will be gratefull you.
Thanks alot
Ramo
Looks like poor geometry. Try right-clicking the object/area and choosing edit geometry. Then choose the 'edit normals' option. Then click the 'detect surface normals' then click okay. Does it help?
kiarash.tamizkar
hey there...it seems you have a normal issue on there..so u have to edit your normals on that region like unify normals or just use a unique smoothing group for all ring subtool polygons..sometimes 2 polygons in same space coordinate and conflict can make this issue in rendering so u have to check your mesh topology there..good luck
Yep, I've had the same issues with certain models, especially if something was modeled with booles (boooo, I know I know) The edit normals function usually fix this sort of thing.
