Author Topic: confused on rotation  (Read 2526 times)
Offline Öner
« on: December 05, 2017, 06:06:04 am »
Hello there, i have a problem about rotation while making a new animation. there are two moves in animation.  Up-down part will move down and then all parts will rotate around the main pivot.  i know that sounds ease, but a problem occurs in this moment.  You will see if you look at the .bip file.
in fact, i've solved the problem but manually.  maybe i've made some mistakes that i've tried everything i know.  Please look at the files as attachment.  i think you can help me. thank you from now.
« Last Edit: December 05, 2017, 06:47:47 am by Öner »
Offline DriesV
  • Administrator
  • Total likes: 49
Re: confused on rotation
« Reply #1 on: December 05, 2017, 06:32:07 am »
I am unable to open the bip file...
Offline Öner
« Reply #2 on: December 05, 2017, 06:49:02 am »
thanks for your attention, i hope you can open it now. thanks in advance
Offline DriesV
  • Administrator
  • Total likes: 49
« Reply #3 on: December 08, 2017, 12:33:30 am »
The fix for this is quite simple.
For the Translation animation "Up_Down part translation 1" you need to set 'Axis Orientation' to 'Original Local'.
Attached is the fixed scene.
Offline Öner
« Reply #4 on: December 08, 2017, 12:59:27 am »
Mate you are the best friend i know.  thank you very much.
