Animation Timeline Guides ?
Started by zooropa, December 08, 2017, 05:19:07 AM
zooropa
Hi. I am setting an animation with a lot parts. All of the are equal and rotate slightly later than the previous. I am fixing this intuitively through the time line, just dragging the green bar. Is there anyway to have some auxiliar lines...that match with the beginning and the end of each animation period ? I would like to understand if they are snapping exactly at the frame I want.
More or less like a 'ruler' in photoshop.
If this is not possible, is there any part of the forum where I can add it as a 'wish'?
The timeline "cursor" snaps on each frame. E.g. set the FPS to 1 and the timeline jumps to each second.
(sorry for the short form)
zooropa
I understand. Just for the sake of 'sketching' the animation just visually. Now I am just following the time line ruler...and matching. Maybe a subtle guide...will not bother the ones using the fps and will add when we need to make a fast test.
What do you think?
