Color invert - bump map
Started by zooropa, January 10, 2018, 12:47:58 AM
zooropa
Hi. I downloaded a 3d block from cgaxis. I believe I need to invert the bump map since KS works with the opposite type of information.
The problem is I the " color invert "  node is not allowing me to connect to the bump channel of my material.
Hope somebody can helps.
Please find attached a an image of the screen.
Edit: I inverted it in PS. Still I would like to know how to do it in KS in order to save the software transition time.
Esben Oxholm
If you change the bump height to a negative value it will work as is it was inverted.
Cheers,
