label mapped over two materials
Started by wolf, January 11, 2018, 01:14:54 AM
wolf
Please can someone tell me if its possible to map a label across two different materials. We have a plastic moulded product with polished and rough areas that we can print onto but in Keyshot I can't see how to get a label to map across two materials. It would speed up my workflow significantly if I could do that.
Currently I have to render the same scene twice and then use photoshop to create the effect.
If I am missing something please let me know. I am using KS 6 but I have paid for the KS 7 upgrade.
Thank you in advance
Robert
designgestalt
hello Robert,
all I can offer you at the moment is a workaround, that might help you ...
If I had to do it, I would do it this way:
1) adjust one of the materials to your needs and apply the graphic in the right size and place.
2)now apply this material also onto your second surface
3) now unlink the material (click Right Mouse Button on your second surface and choose the according option in the window )
4a) you can now either change your material properties on the second surface to your needs or ...
4b)apply a material from the material library while holding the CTRL button pressed. this will keep the label from the former material in same size and place.
I wouldn't know of any other way of solving this problem.
maybe there is a more professional way, which I don't know of ...
hope that helps
designgestalt
Quote from: designgestalt on January 11, 2018, 09:14:05 AM
hello Robert,
hope that helps
designgestalt
^^^ Beat me to it. Have had to do this a couple of times.
wolf
Thankyou Designgestalt, Genuis! Totally works.
Basically, holding CTRL whilst changing material is exactly what I wanted to know and completely solves the problem.
I would write the solution as follows.
- Link the two parts and apply the label in the correct position
- hold down CTRL and drag the correct material onto the desired part
Thank you do much!
designgestalt
