advice required - frosted glass banner
Started by rfollett, February 01, 2018, 11:11:12 AM
rfollett
please see attached.. I guess a label?
Will be a large office so I could just split the geometry on the glass panels (glass top, frost middle, glass bottom)
working with rhino
Will Gibbons
#1
I'd just use a roughness texture made from a procedural texture. Example scene attached.
rfollett
Hi Will,
many thanks, that works very well and easy to move banner up and down..
One question, I see i can change the colour to make frost darker, can I make frost less rough so you can see more outline of the object behind?
http://prntscr.com/i91bxy
many thanks
Will Gibbons
The color is driving the roughness parameter. Black = 0 and White = 1. Roughness of 0 is glossy, Roughness of 1 is very rough.
So, if you want to make the frosted part rougher, make the gray part of the gradient lighter (more white, closer to 1). If you want the frosted part smoother, then make the gray part darker (closer to black, closer to 0).
Does that make sense? The color is not changing. If you want to change the color of the frosted part (which does not make sense for a frosted glass), you would need to duplicate the color gradient and plug it into the diffuse channel and adjust it accordingly.
rfollett
Thanks for your help Will.
If I wanted to do something like this:
http://prntscr.com/ibxa40
is there an easy way? so remove frost to create logo
Will Gibbons
Sure.
Have your logo (black on white with transparency) and use a color composite and set blending mode to multiply.
rfollett
 Thanks Will - sorted...so many options now... never know where to start..
http://prntscr.com/ic248u
rfollett
here is the end result - thanks for your help
Will Gibbons
Looks good! I might increase the exposure (in post) just a tiny bit to give it a more typical architectural feeling to it.
toasty1435
Question on this one, how did you keep the label from reflecting on the back of the glass or casting a shadow behind itself on the glass?
Thanks!
Will Gibbons
Quote from: toasty1435 on August 10, 2018, 08:33:15 AM
Thanks!
You might have luck with unchecking the box 'two-sided' or using center on part mode and adjusting the depth to be very small. If neither of those work for you, you can apply an occlusion texture to the opacity channel of the label and I believe you may need to invert its default settings.
The above should help you out.
