OBJ Export: Error in OBJ file on some vertex normals. --> "vn -nan(ind) ..."
Started by kima, March 12, 2018, 02:57:32 AM
kima
Platform / OS: Win 7
KeyShot version:  7.2 Pro
Plugin version: -
Modeling system, including version: CATIA v4/v5 (not sure, will check)
Steps to take to reproduce the problem: -
  • import model (step file or catProduct) in keyshot
  • export model as obj
  • check obj file to find lines like this one: vn -nan(ind) -nan(ind) -nan(ind)
We intend to use blender in our pipeline and obj is our format of choice. However, this bug leads to a fatal error while importing these files because "-nan(ind)"  can't be parsed as a float value(obviously). We've found a workaround for now: we simply ignore all vertex normals in the blender importer script.
This is not a long term solution. Is this a known bug?
ieatfish
I'm having the same issue. How do you ignore the normals?
