Author Topic: Issue with Interior scene lighting setup  (Read 2844 times)
Offline cereal
« on: March 21, 2018, 03:16:41 pm »
Hey guys,
I've been trying to set up an interior scene in KS7 and I'm having problems with the lighting.
- I'm using 4 panels with an area diffuse light (3 inside the room and one outside behind the window).
- environment is a HDRI
- the room is fully enclosed
- windows are default basic white glass
I've attached some screenshots with the settings as I don't want to share the Bip just yet.
A 3 hour region render with 2000 samples didn't get me any further or should I let it sit for way longer?
Thanks in advance :)
Offline Will Gibbons
Re: Issue with Interior scene lighting setup
« Reply #1 on: March 30, 2018, 09:40:33 am »
You've tried using interior mode?
Offline cereal
« Reply #2 on: March 31, 2018, 08:52:32 am »
Interior mode was enabled
« Reply #3 on: April 02, 2018, 08:18:07 am »
Interesting. It does seem slow indeed. What scale/units is this scene in? And more importantly, what is your machine's CPU specs?
Offline cereal
« Reply #4 on: April 03, 2018, 08:16:51 am »
The scene units are centimeters.
I'm working on a Macbook Retina with 8 GB RAM (1600 MHz DDR3), 2,4 GHz Intel Core i5.
Graphics Card is an Intel Iris 1536 MB.
« Reply #5 on: April 03, 2018, 08:49:08 am »
That's your problem... the CPU is an Intel Core i5. Despite having 4 cores, it lacks hyperthreading meaning KeyShot will only see 4 threads. With an i7, you double the thread count and thus performance.
An interior scene on a machine with an i5 chip will take long. Interior scenes are known for taking longer... you could change your area lights to point lights and they'll be a lot faster, but may not offer the exact appearance you're looking for.
Also, the smaller your rendering, the faster it'll go. Best of luck.
Offline cereal
« Reply #6 on: April 03, 2018, 09:40:53 am »
Thanks Will!  :)
I think I should avoid doing interior scenes with my current set up from now on.
