Black Bars on Render
Started by dxburke, March 26, 2018, 06:07:30 AM
dxburke
I'm sure that this is a silly question, but I'm a total newbie to this thing so I apologize, but when I make a custom render size, I end up with black bars on both top and bottom of the render. Is there a way to get rid of this so it renders out to the custom size that is needed? If anyone can help me out, I'd greatly appreciate it. I'm sorry for the stupid question because I'm sure it's an easy fix.
zooropa
Maybe you can share the scene ? Erase the models if its confidential.
dxburke
Quote from: zooropa on March 26, 2018, 06:24:41 AM
It's not confidential, but I can share the scene set up. Thanks for anyone that can help.
zooropa
You have the backplate option active. If you go to the environment tab and then inside you check the "Background" section you will find the options to set your background. The bars you see are part of your scene setup. Just change it to Background color and white for example. If you move your model you will see it goes above those bars.
Hope it helps .
Regards
dxburke
Quote from: zooropa on March 26, 2018, 07:06:59 AM
Hope it helps .
Regards
Thanks so much! I knew it would be something silly. Thank you!
