Material thumbnails not rendering as it used before
Started by Flavio Hilario, March 30, 2018, 11:37:13 AM
Flavio Hilario
Hello
I noticed something strange ... Opening an old project from KS6, Material thumbnails look better than a new similar project that use same materials imported from KS6 to KS7.
At the attached image, left side = KS6.x project opened in KS7.2. Right side = KS7.2  similar project ( lights, env, materials... )  that uses the same materials previously imported in a separated folder, from KS6.x.  When I ask to Render the Thumbnails, nothing changes.
The difference is because the new light algorithm put in KS7 ?
Is something related to the materials when they got imported?
Is something related to the Windows itself ? ( Windows 8/early10 when it was with KS6.xx .. and now the most recent Windows 10 with KS7.2 )
I guess that you used in KS 6 not the default material environment scene (.bip) from the install folder. And something is wrong with the KS7 installation. I would check and compare the keyshot6.xml and KS7_settings.xml
And then update the entire library.
Hope that helps.
