Problem Mapping Leaf Texture
Started by sarg1994, April 30, 2018, 08:31:06 AM
sarg1994
I am rendering a scene for a park in a city environment. When using any sort of leaf material the material gets warped and only assigns to one corner of the bush. This file was an export from 3ds MAX using the Max to Keyshot plugin. No matter what I do the material only maps to that one portion using UV wrapping. Box and planar do not help and only blow the leaf texture up to cover the entire bush.
I am using a Keyshot 7.2 pro floating license on an HP z240.
Thanks for reading/commenting!
Esben Oxholm
Hi Sarg
I bit hard to troubleshoot. Are you by any chance able to share the KSP?
What happens you you make sure both width and height of the UV map is set to 1?
#2
You can map the same color texture in diffuse and bump channel.
Does it render correct if you change the setting from alpha to color in the opacity channel?
That might remember me of another thread about leafs and opacity.
