Embed Labels
Started by ieatfish, May 16, 2018, 09:58:36 AM
ieatfish
It would be great it we could embed the labels into the bip file. Similar to Adobe InDesign or Illustrator, being able to embed labels would save a lot of headache with packaging and unpackaging when i only need a label or two in a scene.
Quote from: ieatfish on May 16, 2018, 09:58:36 AM
Forgive me if you already know this, but saving as package, i.e. KSP does exactly this. It gathers all your images/links and puts them into a compressed folder so you can share it across computers.
and you can unzip that folder package and pull the labels you need, or do what we do and create a folder inthe texture library for all our labels. On hand all the time to all artists. Same with HDRI's, materials, product colors, etc.
ieatfish
Quote from: Will Gibbons on June 18, 2018, 02:18:22 PM
Quote from: mattjgerard on June 19, 2018, 04:43:17 AM
Thanks guys. I do use packages but when the only thing I need in the package is the labels, it can be a hassle to unzip it every time and resave it as a package when I'm finished. I'll have to just keep doing that.
Another solution that I do personally to avoid this is to have a single textures folder on your machine in which you never remove the textures. That way the link is never broken.
CarlosFerreira
How do you relink broken labels without manually reapplying them if you accidentally moved or renamed the folder with all your textures?
You can restore (put the labels/textures/folders) back to where they were when you created the .bip file and open the keyshot file again. It should see the textures and load just fine. Then you can save it as a .ksp and delete the unused textures at that point.
