LCS or sRGB?
Started by cjwidd, May 31, 2018, 07:47:47 PM
cjwidd
I recently came across this post with the same question.
Is this answer given in the documentation or elsewhere?
I am not sure this is documented explicitly.
KeyShot by default uses a gamma value of 2, both for textures and display. While not exactly sRGB, it is a very close match and should work perfectly fine with almost all textures out there.
Regular users should not be worrying about this, in my opinion. "Linear workflow" is a bad (because highly confusing) solution to a problem that some other tools have, mainly arising from mismatched color management between host modeling app and rendering plugin.
DMerz III
Quote from: DriesV on June 01, 2018, 02:16:07 AM
This is good to hear, Dries, I've been wondering if it even mattered in Keyshot. Either way, I am very grateful it isn't something to worry about in Keyshot, definitely an under-rated feature if true.
cjwidd
Thank you for clarification. I was doing some grey ball tests and realized 50% grey was not correct.
