Wrong Units after import from Onshape
Started by SebastianG, June 22, 2018, 06:44:05 AM
SebastianG
Hello Everyone,
I have a small problem with the current Onshape plugin:
Every time I create a new scene and Import Geometry from Onshape the Units of Keyshot switch to meters, even I created everything in millimeters with Onshape. Also the environment is scaled automatically so I have to zoom a lot and then change the size of the environment.
Starting a new Keyshot Scene and setting the Units to millimeters makes things worse. The Geometry is scaled by the factor of 1000x.
I would be nice if the Keyshot Plugin would use the Onshape Units during import. Maybe you can integrate that in Keyshot 8 please?  :D
Thanks and have a nice day!
