What type of KeyShot material can produce this material?
Started by fa2020, July 06, 2018, 10:17:04 AM
fa2020
What type of KeyShot material can produce this material you see in this image?
The following is a Vray render.
That is a translucent (advanced) material.
You should find similar postings in this forum.
Good luck
fa2020
Quote from: MWo on July 06, 2018, 09:41:13 PM
Good luck
I tried but KeyShot cannot create such a brilliant transluscent and cloudy material.
Can you please share a rendered which has such a material you saw above?
TGS808
Quote from: MWo on July 07, 2018, 01:15:03 PM
BDsign has posted a jade dragon that comes near to your request.
And I believe Eric's dragon was done in KS6. Results in KS7 will likely be even better.
PeterSwift
Quote from: fa2020 on July 06, 2018, 10:17:04 AM
https://www.youtube.com/watch?v=ocEsOtzFPm8&t=4121s
have a look at this new video vould help you out.
of course does lightning and how the 3d model is modeled, does night and day difference on top of adjusting the material.
RRIS
A cloudy plastic will do just fine. All you need is a completely black environment and two small strong light sources. One pin in the back to give you nice backscatter and one in the front to give you reflections on the front of the dragon. (I could probably raise the front panel a bit looking at my image now).
Then it's a cycle of tweaking the transmisison and cloudiness colors, transparency distance and cloudiness. Here's something I made very quickly (and at low samples, since I'm leaving the office now ;) )
RRIS
Here is one with a bit more time in it. Added an IES light going down from the top.
Basic cloudy plastic material. Boosted the saturation / curves a little in photoshop.
TGS808
Quote from: RRIS on July 11, 2018, 01:48:00 PM
Win. Nearly identical to the original example. So much for the superiority of V-Ray.  Well done.
TGS808
Quote from: fa2020 on July 07, 2018, 11:21:38 AM
Ahh... It seems KeyShot can.
RRIS
It's 25% material settings and 75% lighting really.
