Material Study: Enhanced Realism When Creating Condensation via Normal Mapping
Started by bdesign, July 08, 2018, 09:29:04 PM
bdesign
While there is no substitute for the accuracy of creating condensation with actual geometry, I think this technique can enhance the realism and the illusion that the droplets are actually water on a surface when creating them via normal mapping. The trick is to map the IOR of the Glass (Solid) material with a black & white map that corresponds to the silhouettes of the normal map droplets. Plug the b&w map > Source of a Color Composite node, and set the Background to black. Plug a Surface Backside Mask > Source of a Color Invert node. Plug the Color Invert node > Source Alpha of the Color Composite node. Plug the Color Composite node > Input of a Color To Number node. Set the Output From value to the IOR of glass (1.52 in my example), and the Output To value to the IOR of water (1.33). Plug the Color To Number node into the Refraction Index of the Glass (Solid) material. This setup manually emulates the Refraction Index/Refraction Index Outside options of the Dielectric and Liquid type materials, with the benefit of being able to map them. Example renders below are:
1. Glass with IOR mapping setup
2. Glass without IOR mapping setup (IOR set at 1.52)
3. Normal map and corresponding IOR map
Coca-Cola glass model from GrabCAD by Ahmed Zawad Ul Hoque Shovon.
Cheers,
Eric
Wow Eric.
You know how to amaze users!
Great job and good tutorial!!!
That made my day. Thank you.
bdesign
DMerz III
Very nice!
Will be even more impressive in 8 when you can utilize the displacement map  ;)
feher
bdesign
Quote from: Will Gibbons on July 11, 2018, 04:47:09 PM
Great material study. Nice execution!
Thanks very much, Will! I appreciate you taking a look  :)
Cheers,
Eric
bdesign
Quote from: feher on July 11, 2018, 06:25:43 PM
Very nice ! Thanks for sharing your workflow.
It's a keeper.
Tim
Thank you kindly, Tim! You're welcome  :)
Cheers,
Eric
Hossein Alfideh
Hey Eric.
I'm Pretty sure that you willl LOVE KeyShot 8!!!
bdesign
bdesign
Quote from: MWo on July 16, 2018, 10:44:06 AM
Hey Eric.
Hey Marco. I'm sure KS8 will be awesome! I haven't even had a chance to play with KS7 yet . . . still on 6.3.
Cheers,
Eric
Quote from: bdesign on July 16, 2018, 12:34:23 PM
NOOOOOOOOO!!! You should get on the Beta when it's open (soon)
Despot
