problems with splitlines
Started by Enebrand, July 10, 2018, 08:05:46 AM
Enebrand
Hi!
I have a model that is imported from solidworks to keyshot (using the plugin) and then rendered as nurbs. The problem I have is that some splitlines looks like its broken/not rendered correctly (see attatched image).
Anyone know why this happens to me?
Cheers Andreas
Why would you render with NURBs on? Try rendering with that turned off. :)
What method did you use to import the model into KeyShot? What file format was imported?
