Issue with 2 bump maps
Started by Zvi, July 10, 2018, 12:17:58 PM
Zvi
I use two Bump maps in the same object, one has a texture that covers the entire object, and the other has a logo. Now the two maps fit together, but I want the map with the logo to cover the texture map so that where the logo is  visible, you will not see the texture.
Finema
Hi
here a simple example  ;)
Zvi
#2
Thanks Finema, but in the downloaded bip file there is only 1 bump map, and it's hard for to understand the way to do it only by the attached print screen. maybe you can explain it, it really can help...
Finema
in the bip file there are 2 bump map
you must open Material Graph ;)
