Author Topic: Issue with 2 bump maps  (Read 3372 times)
Offline Zvi
« on: July 10, 2018, 12:17:58 pm »
I use two Bump maps in the same object, one has a texture that covers the entire object, and the other has a logo. Now the two maps fit together, but I want the map with the logo to cover the texture map so that where the logo is  visible, you will not see the texture.
Offline Finema
Re: Issue with 2 bump maps
« Reply #1 on: July 11, 2018, 01:13:35 am »
Hi
here a simple example  ;)
Offline Zvi
« Reply #2 on: July 11, 2018, 03:32:49 am »
Thanks Finema, but in the downloaded bip file there is only 1 bump map, and it's hard for to understand the way to do it only by the attached print screen. maybe you can explain it, it really can help...
« Last Edit: July 11, 2018, 03:40:44 am by Zvi »
Offline Finema
« Reply #3 on: July 11, 2018, 06:29:28 am »
in the bip file there are 2 bump map
you must open Material Graph ;)
