experimenting with human skin
Started by mirko, July 28, 2011, 02:22:31 PM
mirko
are you using the skin material from the library?
feher
Very nice start ! You might be on to something here. just get that high shine off the skin and lets see what it looks like.
Keep at it.
Tim
mirko
Quote from: Thomas Teger on July 28, 2011, 02:38:54 PM
No, I've done a new one
I can tell - that's why it doesn't look like skin. The skin material in the library is accurate ...
mirko
Quote from: Thomas Teger on July 29, 2011, 07:36:45 AM
same scene, less brightness of the environment, and default skin material (only scaled bumpmap)
elliasp
Yes, Thomas is right...
Skin should be shiny but not everywhere, look this exemple below : Shiness is folowing the "bump map"... or skin imperfections...
hope it helps  :)
Zvi
Would you share with us your material?
Esben Oxholm
Quote from: thomasteger on July 30, 2011, 07:01:26 AM
Hmmm - still a bit too shiny ...
Unless she is covered in a thick layer of lube  8)
What look are you going for here? Might help to give some feedback.
Realistic looking skin or a more artistic approach?
Zvi
Quote from: Esben Oxholm on September 14, 2016, 11:14:43 PM
Hi Esben,
I'm looking for a realistic look. This is what I got from the KeyShot Skin material.
Dylan
In that last render, I think it shows you are not making the most of the Keyshot stock skin materials. There are tons of tweaks that can be done, for instance translucency adjustments alone can make it look very realistic.
