Import multiple .STL files as single Alembic File
Started by SebastianG, July 23, 2018, 10:44:36 AM
SebastianG
Hello everyone,
I got a lot of .STL files of a water simulation and I would like to know if there is a possibility to convert them to Alembic Format (.abc)?
At the moment I have to import each .stl manually, calculate the normals (edit geometry), group them (carfully). Then I hide all .stl except one and add the current view to the render queue. I have to do that for each frame  :(
Well it takes ages and I wondered if there is a better way to do that?
I searched but I could not find a converter to save all .stl files in a single .abc file.
Where are your files coming from (what software are they made in?)
SebastianG
Currently I'm doing some fluid simulations with SimScale which is a cloud Simulation Platform.
I create Multi-phase simulations with water and air. SimScale uses OpenFOAM as Solver.
Here is an example how the simulations look like:
https://youtu.be/txqcePmnTVU
I can download the results and open them in ParaView. Then I extract the "surface" between the water phase and air phase. Finally I can export stl-Files of each time step. Unfortunately I could not find a way to export to alembic format  :(
