Hello guys,
I have a problem to find the perfect water material. Indeed, I did many tests (see exemples below : water material with IOR 1,200) and a high level of raybounce...
I tried every IOR possible, every levels, and I even tried to replace water or liquid material by gem or glass and solid glass : the result is always the same : Water object has very important areas in grey, as you can see on the render below...
If the raybounce is low, water is black. If the raybounce is high (I tried till 23 !) the result is gray...
Maybe it's in advanced material ?... Can you help me ?...
F
