Author Topic: Abstract 8  (Read 2859 times)
Offline m0dm0d
Abstract 8
« on: September 21, 2018, 01:25:24 pm »
Hi all
For my image, I've experimented with Cinema 4D R20 (along with the new volume builder), to create the noise field sitting behind a transparent number 8.
I brought my volume mesh into Keyshot 8 Beta as an Alembic file, applied a scattering material and positioned a few coloured spotlights in the scene. I then used Image Styles to adjust the tone slightly, then added a little further post in After Effects, where I export my final animation sequence.
Cinema 4D R20 and Keyshot 8 seem to work so well together, allowing me to experiment in ways I wasn't able to before...with my current setup at least... (we just need that Keyshot to R20 bridge plugin next)  ;)
I rendered the 61 frames with 80 samples, a little pixel blur, plus anti-aliasing over the network.
I'm uploading the animation here with a small bitrate (for a 5.6 mb file size) – I also have a smoother version where the file size is 18mb.
The execution is not perfect, by any means... but was a fun little exercise to go through.
Once I get my head around the new features (for both C4D and KS8) I plan to explore some more ideas using this technique.
Mark
@m0dm0d
Offline LM6
Re: Abstract 8
« Reply #1 on: September 21, 2018, 01:45:10 pm »
I like this and I like how you made it,  haven't really got started with R20 but a Keyshot bridge makes a lot of sense.
