problem with white paint material
Started by fario, October 16, 2018, 03:18:42 AM
fario
I think there is a problem with the rendering of the material: white paint.
Keyshot pro 8
There are artifacts on the surface.
Thank you for your reply.
fario
Same results after render 256 samples.
It reminds me of the same bug with version 5 or 6, I do not know anymore.
Could you please, give an explanation?
Thank you so much.
Antoine
DMerz III
Are you referring to the fireflies? (hot white dots everywhere)
Couple of things I would try.
- Instead of White Paint, try making the shader a plastic, and turning the specular from pure 100% white to something lower)
In reality, surfaces never reflect 100% white light, that has been known to cause some issues such as fireflies in the past.
I don't know what your render settings are, but if you have a realtivly low scene sample rate, you'll also never clean those fireflies up. Try messing with the product/interior mode?
fario
Thank you for your answer.
I never had this problem with v.7, with the same scene.
I tried your proposals without success.
Antoine
Hi Antoine,
Could you share this scene with us?
fario
