Author Topic: Multi material label  (Read 2756 times)
guest93635
  • Guest
« on: October 17, 2018, 09:54:28 pm »
Hello all!
This is my first post, I'm currently learning Keyshot and really enjoying it so far. Apologies if this has been covered off in a separate topic I'm not sure if I'm searching under the right topic.
I'm from a packing background and designers are often using a mixture of foils, gloss and matte finishes. I'm not sure how to apply these different types of finishes to a single label.
Using a typical Monster can design as an example set up for print as follows:
The "label" would be the black background with the green M and monster title under it.
The Black area would be (for example) Matte
The M would be a Green foil with a naturally gloss finish.
The Monster Title would also be in gloss.
In my Adobe Illustrator mind everything would be layered and materials added to each layer but I cannot translate this into how Keyshot functions.
Any advice would be really helpful, once I know this the sky's the limit! (Hopefully!)
Offline Esben Oxholm
Re: Muti material label
« Reply #1 on: October 17, 2018, 10:36:34 pm »
Hi 3star.
Check out this webinar at 42:00 - I think it shows how to do exactly what you are asking for.
Cheers,
https://youtu.be/5umbUNOT6HI?t=2521
guest93635
  • Guest
« Reply #2 on: October 17, 2018, 10:55:46 pm »
That's great, will check it out now. Thanks so much!
Offline DriesV
  • Administrator
  • Total likes: 36
« Reply #3 on: October 18, 2018, 02:28:42 am »
More detailed information on the Color Key Mask node can also be found in the manual here.
guest93635
  • Guest
« Reply #4 on: October 18, 2018, 04:24:41 am »
Thanks so much!!!
guest93635
  • Guest
« Reply #5 on: October 18, 2018, 07:49:53 am »
Worked perfectly, thanks so much guys!
« Reply #6 on: October 18, 2018, 12:25:55 pm »
Good to hear!
