Keyshot 8 tumble 3D object lagging
Started by tbjerman, October 18, 2018, 02:17:06 AM
tbjerman
When I try to rotate / pan 3D object in Keyshot 8 , the 3D object movement is lagging. It also happen when I rotate the environment map. This happens when CPU core usage set to 100 %.
However everything become smoother when core usage set to 50%
My PC spec :
Win 7 professional  SP1 -64bit
Intel Xeon CPU E3-1220 v5 @ 3Ghz
16GB RAM
Nvidia Quadro P1000
Were my system not good enough to run keyshot 8 ?
Pls advise.
Thanks.
Jerman
Rex
Hi Jerman,
I can see that this CPU does not support hyper-threading which would help speed things up.
Until you're able to upgrade your CPU/system I recommend working in Performance Mode to get a smoother experience during scene setup.
