How to turn lights on then off in animation?
Started by jeffdebord, October 22, 2018, 07:15:56 AM
jeffdebord
I have an electronic product we are animating and need to start with led/ emmissive off, then  turn on then back off agai. how is this done. I can turn them on with the number fade, but no option to turn back off.? am I missing something?? KS 8
Rex
You will have to use the color fade animation using black and white color stops to do this.
It you can overlap the emissive part with a solid one. So you can use the fade animation.
Similar to the strobo effect post in this forum.
https://www.keyshot.com/forum/index.php?topic=21620.msg92081#msg92081
Hope that helps
Like Rex, I'd recommend the color fade to do this. Quite a bit simpler and arguably more robust than multiple fade animations. Though, both will likely get you there.
