Moving labels
Started by joseph, October 28, 2018, 01:05:02 AM
joseph
When inserting labels, positioning handles usually display to size or move. It was working last but it doesn't show up anymore. I already did a reboot and still won't come up. I opened a previous file that I have set the label and set Move Texture, still doesn't work. Do I need to re-install KeyShot?
Please advise. regards
In this case, I would first try to re-install KeyShot. And if it doesn't work either, I guess there were changes in graphics driver or settings.
Hope that helps
Good luck.
joseph
Hi Marco,
I found the problem. There are two versions of source files as it represents a base model and the other with a feature. The naming convention was culprit and confused  ??? KeyShot.
All good here, thanks Marco
