Author Topic: HDRI Problem!  (Read 3013 times)
Offline JoshASharp
HDRI Problem!
« on: November 06, 2018, 03:10:25 am »
Hi all,
I'm currently trying to re-do some catalogue renders, however regardless of the HDRI I use I always get this big bright spot, it changes position as I move around the model which leads me to believe it's something to do with the camera maybe? Attached is a photo of the issue.
Thanks,
Josh
Online INNEO_MWo
  • Total likes: 23
Re: HDRI Problem!
« Reply #1 on: November 06, 2018, 10:25:42 am »
As far as I can notice, there could be several things done.
- update to the latest version of KeyShot 6(.3.36)
- create a new HDRI with a pure white background as “all white” do.
- replace confidential geometry with a simple one (cube) and apply the same material.
- share the scene, that we can help.
I guess it depends on the size of the environment, which seems to be way to big as it needs to be.
Hope we’ll found the solution.
Offline KeyShot
Re: HDRI Problem!
« Reply #2 on: November 06, 2018, 08:40:17 pm »
Can you share the model, so we can see the issue?
Offline JoshASharp
Re: HDRI Problem!
« Reply #3 on: November 08, 2018, 09:21:59 am »
Yeah I can, I've tried saving a ksp package file but it wont let me upload it as I think it may be too large - around 30mb? Any advice?
Online INNEO_MWo
  • Total likes: 23
Re: HDRI Problem!
« Reply #4 on: November 08, 2018, 09:39:21 am »
Reduce the geometry and the resolution of the hdz file
Offline bdesign
Re: HDRI Problem!
« Reply #5 on: November 08, 2018, 12:05:49 pm »
Hi Josh-
Is there by chance also a plane in your scene with an Area Light Diffuse material applied, with "Visible in Reflections" enabled?
Cheers,
Eric
Offline Will Gibbons
Re: HDRI Problem!
« Reply #6 on: November 13, 2018, 09:35:56 am »
You can upload to wetransfer, and paste a link here to download if you wish. Size won't be an issue.
Offline JoshASharp
Re: HDRI Problem!
« Reply #7 on: November 13, 2018, 03:42:56 pm »
Sorted it out now! It was an emissive plane that I hadn’t turned off hah, although I will upload the scene I was doing to wetransfer to get some feedback off everyone
