Transparency and Normal Map
Started by Jesse.Art, November 22, 2018, 01:12:17 AM
Jesse.Art
I'm having trouble with getting my normal map to show up using the Translucent(Advanced) material. Is there some sort of issue with it or am I missing something?
bdesign
Hi arsmod-
An image would be helpful. My first thought is, have you enabled the  "Normal Map" option check box under the Bump Height slider?
Cheers,
Eric
Jesse.Art
#2
It's checked. I've used the translucency material before but have never tried using a normal map with it. If I change it to the advanced material then the bump displays properly. If I then go back to translucency, it disappears.
The normal map is for her skin texture. I've included screenshots from both materials as well as the settings for the normal map.
#3
I can't recreate this issue in KeyShot 8.1.58 (current version)
left cylinder - translucent with normal map
right cylinder - translucent (advanced) with normal map
