Vintage Grundig Majestic 1088 Radio
Started by Serhan Yenilmez, November 25, 2018, 02:37:26 AM
Serhan Yenilmez
My 2nd contribution. Hope you would like it. :)
Modeled entirely within Solidworks and rendered via Keyshot 8 including built in post process image effects. The only extra render pass was AO which is later added on to RGB pass in Photoshop. The most challenging part was the dial screen. I had to draw the entire graphic piece as separate vector images, and then composed those four label layers on to a Keyshot plastic material.
jhiker
Terrific. Some fabulous materials there!
Loving the wood. Is the tuning scale a label, and what texture map did you use for the speaker grill?
Serhan Yenilmez
#2
Quote from: jhiker on November 26, 2018, 05:08:15 AM
Thank you, much obliged.   ;)
The wooden mat is from the standart Library with a little tweak.
Tuning scale has 3 separate label s(Gold, Grey, Black) on a Black glossy plastic material.
As of the grill, I extracted the seamless texture out of a high res photo of an original radio itself.
Weezer
Really lovely modelling and texture work. My only suggestion would be to use a greyscale vision of the grill as a displacement map, then it would actually have the same ridges and bumps of the original.
Serhan Yenilmez
Quote from: Weezer on November 27, 2018, 06:55:07 AM
Thank you. Actually I did, but I was afraid of pushing it hard so it might be decayed in the process. :)
Serhan Yenilmez
Pouya Hosseinzadeh
Closeup shots are killers! well done man!
Serhan Yenilmez
Quote from: PouyaHosseinzadeh on November 28, 2018, 06:49:20 AM
I am glad you liked it. Much appreciated. :)
Saskia
Love It, picture 3 & 5 are my favorites
Happy New Year
feher
WOW ! Just WOW.
Those close up shots are just stunning.
Thanks for sharing.
It's a keeper in my book.
I want to see more !
Tim
KeyShot
Awesome image and lovely details. As others have mentioned a bit more use of displacement mapping would take the little details in the close-ups to the next level. Happy New Year!
Robb63
Wow, that light scattering across the varnish on the lower logo image (picture 5) is amazing!!
Magnus Skogsfjord
That really is some awesome material work. Well done all around! +1
Josh3D
Wow! I do believe I missed this one. Simply stunning!
