Author Topic: Displacement+curvature?  (Read 2337 times)
Offline PeterSwift
« on: November 28, 2018, 06:01:18 am »
If I wanna apply a bump on the negative curvature. The surface thats not extruding out from the body with displacement. Is that possible?
I don't get the Curvature "texture" to see the displacement.
+ Could be my 3D model. Becouse I don't see any color changes when I look at the curvature after clicking "C"  everything is Zero curvature. So I guess I might need to fix my UV.
« Last Edit: November 28, 2018, 06:11:58 am by PeterSwift »
Offline DriesV
  • Administrator
  • Total likes: 33
Re: Displacement+curvature?
« Reply #1 on: November 28, 2018, 06:17:52 am »
No, this will not work. Unlike the other procedural textures, Curvature, and Occlusion, are raytraced textures and will not work as expected for displacement.
Offline bdesign
« Reply #2 on: November 29, 2018, 02:37:23 pm »
Hi Peter-
If you first add displacement to geometry and then create a Curvature node in the MatGraph, and use the "C" color preview, you'll see that the Curvature texture is respecting the displacement. So, you could use the Curvature node as "Bump Height" for your bump texture. For more precise control of the bump height, you could run the Curvature through a Color To Number node.
Cheers,
Eric
« Last Edit: November 30, 2018, 12:10:28 pm by bdesign »
Offline DMerz III
« Reply #3 on: November 29, 2018, 03:45:03 pm »
Frickin' brilliant, Eric. I didn't even think of that. Thanks for sharing, once more.
Offline Finema
« Reply #4 on: November 29, 2018, 09:51:49 pm »
Really good Eric !  ;)
Offline bdesign
« Reply #5 on: November 30, 2018, 12:12:23 pm »
Thank you both, David and Philippe! I appreciate the kind words.
Cheers,
Eric
