Displacement Maps do not render when using Network Render
Started by monson67, November 30, 2018, 09:35:12 AM
monson67
Mac OS 10.14.1 (also used as NR master), KeyShot 8.1.61, KeyShot Network Render 8.1.61
I've applied displacement maps to a number of different materials and sent them to the Network Render, only to have the displacement maps disabled/discarded, resulting in a flat appearance. Without changing any settings, if I have my local machine render the image, it appears as it should, with the displacement map generated and rendered out. Anyone else have this issue?
KeyShot
Displacement maps do work with network rendering. If you have a specific file that fails then please share it with support@luxion.com, so we can take a look at it.
