Unsmoothed geometry importing from Rhino
Started by Schembri23, December 06, 2018, 03:55:37 AM
Schembri23
Hope somebody can help me out with this.
Every time I import a model from Rhino into Keyshot, I can't render any close up or the polygons would be more visible.
Surfaces should be smooth but they are not, specially in the borders.
I tried to export in obj but it's the same.
Esben Oxholm
Hi!
What are your import settings?
Looks like you need to import with a higher tessellation value (or set it on export depending on the file type).
Can you share your import settings?
Magicmez
Have a look on this and play with the meshing options in rhino. This should solve your problem.
https://wiki.mcneel.com/rhino/meshfaq
Regards,
