Transparent BG; no longer?
Started by DMerz III, December 11, 2018, 09:05:26 AM
DMerz III
Hey guys,
I'm completely dumbfounded at the moment, I thought I used to be able to render an image in .tif format with transparency turned on, with a physical ground plane set to the default ground material, and get an output image where the shadow blends off into alpha transparency. Is that no longer an option in KS8?
DMerz III
 :-[ Figured out my issue. I wasn't rendering in product mode. I couldn't get it to work with interior mode. (I usually work in product mode). Is that probably the culprit?
FJEGA
#2
they say refraction makes inaccurate background (in astill image!), so they  taken away the issue
only basic glas works, so i need liquid inside a glass i cannot
Now i have to guess those letters below
